I have latest version of XamMap (latest service release) and if I add 100 SymbolElements, and a shape file of 50kb with ~50 shapes, navigation (e.g. zooming in and out) gets already quite slow. I feel that the number of SymbolElements is affecting the performance quite drastically.(more than the size of the shapefile does)
If I add 1000 SymbolElements (small .png file), Navigation becomes virtually impossible. On Bing Maps Silverlight control, I was previously able to add 5000 elements and navigate still quite smoothly.
The threshold of a smooth navigation is too low. I already add all the SymbolElements in one go to the ElementCollection, and 100 data points is not a whole lot.
This low performance is a show stopper for us using Infragistics XamMap (or stopper for buying additional licenses). Is there any way Infragistics could look at improving the performance?
Thanks for letting me know.
Roel
Hello Roel,
I am just checking if you were able to decide on using an untested build and if this is still a possible solution for your scenario.
I understand your predicament and usually we can provide an untested version of our internal build, however this also requires some technical time and it is already the end of the month. Could you please elaborate if such an untested version would be acceptable for your project and what is the deadline you have for switching references in your product.
Here you go.
Problem is we already release by the end of this month which is too late to onboard the latest service release for 10.3. Is there any way I could get a version with performance improvements earlier?
Hi Roel,
Is everything OK now? If yes, could you also Suggest as Answer my post?
Alex
I have been looking through your thread and am really glad you like the improvements in the XamMap, however the 10.3 license allows only 10.3 usage, no newer nor no older version can be used with the same key. If you want to discuss your options for migrating I can suggest you reach our sales department at Sales@Infragistics.com.
Also you should be aware that the improvements in 11.1 are going to be merged in the upcoming Service Release for 10.3 to the extent to which the 10.3 functionality allows. I can suggest you wait for it to become available and test out if it would be enough for you scenario. You can check upcoming Service Release shipping dates here: http://ko.infragistics.com/support/documentation.aspx#ServiceReleases
Please let me know if we can assist you in any other way.
