The published roadmap for Silverlight Data Visualization seems to describe new features that are already available in the current release. Can you provide some information on what will be available in the next release?
In addition, do you have any plans to introduce a Decomposition Tree control?
Gary
Thank you, Jason. The upcoming features sound great. You are correct that my use of tje Decomposition Tree would be with OLAP data. I did look at the Network Node Map as a possible solution, but did not think it was a good fit.
Hi Gary -
You can check out the roadmap here, I posted the 11.2 list last week:
https://ko.infragistics.com/community/blogs/b/jason_beres/posts/coming-this-fall-a-sneak-peek-at-11-2
I'd love to hear your feedback on it. We do not have a Decomposition Tree (exactly). It is on the roadmap. I am checking with the IXD guys to see if the Network Node Map can perform a similar function. My understanding is that the normal use case for this is around the path of OLAP data? Or are you thinking flat data?
Thanks for any more info, and let me know if there is anything else I can help out with.
Jason
