920
Changing Pivot Grid's ItemsSource
I have a XamPivotGrid that gets its data from an xml that is filtered according to a start and end date the user chooses.
So every time a user changes the start and end date i call the function that filters my xml and then change the pivot grid's ItemsSource like below:
ObservableCollection<MarketShares> mSharesData = SampleDataGenerator.GenerateMarketShares((DateTime)this.datepicker1.Tag, (DateTime)this.datepicker2.Tag);
((FlatDataSource)this.pivotGrid.DataSource).ItemsSource = mSharesData;
this will affect the view of the grid. Meaning that the grid will collapse and i will see the Total View only unless the user clicks to expand. I tried calling the ResultsChanged function to expand the view like below:
this.pivotGrid.DataSource.ResultChanged += DataSource_ResultChanged;
it worked, but the grid is being refreshed in a very obvious way where you could capture for a second the Total View being expanded. Is there a way to have the grid expanded in a less obvious way?
nazha
