115
WbeNavBar doesn't work in Mozilla 10.0
I am using  Infragistics.WebUI.UltraWebToolbar.v4.3 in asp .net 4. this web nav bar  works in IE9 but doen't work with the mozilla.
Here is the exception i get when i load the webNavbar
Can anyone help me on this issue
[FormatException: Input string was not in a correct format.]
   System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) +9585931
   System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +119
   System.Convert.ToInt32(String value) +48
   Infragistics.WebUI.UltraWebToolbar.UltraWebToolbar.getRenderer() +606
   Infragistics.WebUI.UltraWebToolbar.UltraWebToolbar.PreRenderToolbar2(Object sender, EventArgs e) +177
   System.EventHandler.Invoke(Object sender, EventArgs e) +0
   System.Web.UI.Control.OnPreRender(EventArgs e) +8991986
   System.Web.UI.Control.PreRenderRecursiveInternal() +103
   System.Web.UI.Control.PreRenderRecursiveInternal() +175
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2496
