I am using xamTree control in my silverlight4 applicatiion I want to bind data to xamtree control.
It only binds nodes upto 600 and after that children nodes are not displaying.
Is it the limitation of xamTree control or need to look into the code.
Urgent reply appreciated.
Thanks!
Hello Sanjay,
Excuse for the late reply, I have been looking into your enquiry and usually there is no such limitation for the XamTree’s data items and I haven’t encountered such an issue before. At this point I can assume this might have something to do with the data source you are using, however I would need to look into your sample in order to try and spot what is the actual cause.
Sorry for late reply,
I am using MVVM pattrern with PRISM architecture.
I have a node below that I have to display say 10K child nodes I cant just click on expand and wait till time out to come. To avoid this I am adding "More.." node after say displaying 10 child nodes and when user clicks/expands on "more.." node next 10 childrens are displaying. now the question is I can do this only upto 6 times I have tried to change the number of records from 10 to 5 but same case with that.
looking forward more hearing from you.
Hi Peter,
Thanks for your response,
Actually I would more interesting in knowing about the hierarchy levels.
Please refer treeview structure on this site:
"http://blogs.msdn.com/b/carloc/archive/2007/05/23/broken-line-in-asp-net-2-0-treeview-in-ie-7.aspx"
Something like this I want. But I can only drill down upto 6 levels that is a issue.
Sanjay
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
I am still have trouble about the XamTree .
I am not able to attach the sample code I am getting 500 error in this forum.
I have used the sample code(MultiTree) which I picked from one of the samples that you have. (http://ko.infragistics.com/products/silverlight/sample/tree/#/expand-and-collapse-nodes)
I tree node is not having expandable arrow at level 4.
Please suggest me the solution.
I have been looking into the sample project you referred and in it there are only 4 DataTemplates defined, which is the number of data levels shown. This is a limitation of the XamTree and in this is why we had created the XamDataTree, which can have a GlobalNodeLayout set for all the available levels of data. In the sample I had created for you there are 9 DataTemplates added for the ItemTemplate and HierarchicalItemTemplate properties, which actually causes the difference in behaviors.
Please let me know, if Í can be of any further assistance.
Hi Petar,
Thanks for your response.
I got the solution on this I have added more DataItem Template as I want in design mode.
But just want to know how do I create DataItem Template at runtime depending on data source.
thanks
