Hello there , we confront a problem when trying to use Coded UI Test (CUIT) feature of MS-Visual Studio 2012 SL-plugin ( http://visualstudiogallery.msdn.microsoft.com/28312a61-9451-451a-990c-c9929b751eb4 )for one of our SL application built with Infragistics control. I hope , i dont need to explain on the process of CUITs , but the problem occurs when `Coded UI Test Builder (the plugin)` is recording actions of the application and when clicking XamDateTimeInput - it generates an error saying `An exception occurred when trying to discover info about a sl control` and the process stops abruptly.
Note that it does not have troubles with other `XAM`controls so far.
Any idea ?
NB: As per you , what is the best recommended TestTool for SL apps with Infragistics for Performance,Load , Unit ,UI Testing ?
HI,
Since MS dropped official support for codd ui tests with SL5 and VS2012 we can not support this feature.
http://social.msdn.microsoft.com/Forums/en-US/ee9c12af-5b11-4d51-8dee-fc9d4d42faae/coded-ui-tests-are-supported-for-silverlight-5-in-visual-studio-2012-?forum=vsautotest
http://msdn.microsoft.com/en-us/library/dd380742(v=vs.110).aspx
http://blogs.msdn.com/b/bharry/archive/2012/07/09/coded-ui-testing-support-for-silverlight.aspx
Please let me know if you need further assistance regarding this issue.
HI Thomas,
I have asked the developers to take another look at this issue.
Thanks for the status update.
Hello Matt
Thanks for your reply,
Ref to the above, I will definitely come up with an answer after I consider your recommendations on 20.09.2013.
As a matter of fact, we moved on, from the problem listed as it was logged around 5 months back.
Please let me know if you need further assistance regarding this case.
