no problem.
In our web.config we have an entry which specifies which javascript files to use.
infragistics.web javaScriptDirectory="~/ig_common/JScripts">
</infragistics.web>
if you update the javascript files in this location with the new ones that should be enough. Maybe you have to delete the cache before the changes will take affect.
OK. We also did an upgrade to 8.3. So, how did you tell it to use the new JavaScript file?
Sorry, I am new at this. :)
yes i think these files should be automatically generated when they are needed. However because i carried out on update the old javascript files were still in my web application.
an example of these files are:
ig_WebGrid.js
ig_webtoolbar2_2.js
if you open them in a text editor then it should tell you the version number at the top like this.
/** ig_WebGrid_an.js* Version 8.3.20083.2039* Copyright(c) 2001-2009 Infragistics, Inc. All Rights Reserved.*/
Thanks for the help!
Could you explain more how you copy the new JavaScript files? As far as I can tell, I have not added any Infragistics JavaScript files to me project. Where do you find them at? How do you know if you are using old versions of JavaScript files?
I know that some JavaScript files are generated when I run my project. Is that what you are talking about?
I have just found out the problem in my environment.
I forgot to copy the new javascript files to my application after the update. They have changed between versions 7.1 - 8.3.
I also had to clear my tempory internet file cache as i have caching enabled on my machine.
I hope this helps somebody in the future.
