I am using following code to set the properties of the ultrawebgrid, When tried to select a row in the grid for IE 9.x, It is selecting for the first time, but from second time, it is not getting selected ( highlighting) the row.
dg.Width = Unit.Percentage(100); dg.BorderStyle = BorderStyle.None; dg.DisplayLayout.HeaderStyleDefault.BorderDetails.StyleLeft = BorderStyle.None; dg.DisplayLayout.HeaderStyleDefault.BorderDetails.StyleTop = BorderStyle.None; dg.DisplayLayout.HeaderStyleDefault.BorderDetails.StyleRight = BorderStyle.Solid; dg.DisplayLayout.HeaderStyleDefault.BorderDetails.ColorRight = Color.FromArgb(246,244,236); dg.DisplayLayout.HeaderStyleDefault.CssClass = "GridHeader"; dg.DisplayLayout.RowStyleDefault.BorderStyle = BorderStyle.None; dg.DisplayLayout.RowStyleDefault.CssClass = "GridRow"; dg.DisplayLayout.RowAlternateStyleDefault.CssClass = "GridAltRow"; dg.DisplayLayout.Pager.Style.CssClass = "PageRow"; dg.DisplayLayout.FooterStyleDefault.CssClass = "GridFooter";
dg.DisplayLayout.CellClickActionDefault = clickAction; dg.DisplayLayout.ActivationObject.BorderStyle = BorderStyle.Solid; dg.DisplayLayout.ActivationObject.BorderColor = Color.FromArgb(212,195,102); dg.DisplayLayout.ActivationObject.AllowActivation = true;
dg.DisplayLayout.SelectedRowStyleDefault.CssClass = "GridSelectedRow"; dg.DisplayLayout.SelectTypeRowDefault = selectType; dg.DisplayLayout.StationaryMargins = StationaryMargins.HeaderAndFooter; dg.DisplayLayout.ColFootersVisibleDefault = showFooter ? ShowMarginInfo.Yes : ShowMarginInfo.No; //dg.DisplayLayout.AutoGenerateColumns = false; dg.DisplayLayout.AllowSortingDefault = AllowSorting.Yes; dg.DisplayLayout.AllowColSizingDefault = AllowSizing.Fixed; dg.DisplayLayout.RowSizingDefault = AllowSizing.Fixed; dg.DisplayLayout.RowHeightDefault = Unit.Pixel(20); dg.DisplayLayout.HeaderClickActionDefault = HeaderClickAction.SortMulti; dg.DisplayLayout.RowSelectorsDefault = RowSelectors.No; dg.DisplayLayout.TableLayout = TableLayout.Fixed;
Please let me the solution.
I installed latest version of infragistics and trying to upgrade, but I could not find UlgraWebGrid object in the latest release. I have posted a query on the website for help
http://ko.infragistics.com/community/forums/p/86527/431536.aspx#431536
It would be good if you can provide me a solution for this.
I'm just checking if you have further questions on the matter.
There are some issues with v10.2 and IE9. I would suggest you to upgrade to the latest Service Release of 10.3 where they are fixed and see if the issue still occur.
Let me know if you have any other questions.
Row selection/highlight code is working fine in IE 8, When it is accessed in IE 9 , the same code is not working.
After page load
1) Select a row --> Row is getting highlighted.
2a) use Grid scrollbar - Scroll down , Select a row --> Row is not getting highlighted.
OR
2b) Select another row --> Row is not getting highlighted.
Please let me know if you need more details.
Hello Paul,
I'm not sure what you are trying to achieve. If you want to select a row in code, please have a look at these articles, explaining how to do this:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=2798
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=2802
Hope this helps.
