We are using Infragistics controls V11.1 (Ex. Infragistics2.WebUI.UltraWebListbar.v11.1 with file version 11.1.20111.1006) in our projects but they are crashing in IE10 and 11 with the message "Input string was not in a correct format.".
Can you please let me know which is the best way to fix this issue, ( as I understood the latest infragistics goods had retired some of the controls in v11.1)
Also I have download and use NetAdvantage_ASPNET_20111.2064_VersionFree_CLR4 goods but that even not working for me.
Thanks in advance.
Pallavi,
If you are using the retired controls, they were not supported in IE 11 and it is recommended that you replace them with either the Ignite UI controls or the new ASP.NET AJAX controls.
Let me know if you have any questions with this matter.
Hi, my issue is this only, the infragsitics scripts are getting loaded properly in compatibility view but not in normal IE.
I cannot deliberately ask user to switch their IE to compatibility view, i have tried using meta tags in the html, that didn't work either.
Any help would be appreciated.
Vasanthi,
Is IE in compatibility mode? If not that may resolve the issue.
HI,
I have resolved this issue and application is launching properly in IE11. but UltraWebgrid functions are not working like cell click event etc.. after upgrade, and page also shrinks in IE11.
Vasanthi
The UltraWebGrid was retired before IE11 support was added to the ASP.NET toolset.
I haven't seen the specific behavior you are describing and recommend that you do some debugging to see what may be causing the issue. A few questions that will help you look into this:
