120
Using WebMenu inside WebAsyncRefreshPanel
I have a WebMenu that I would like to place inside a WebAsyncRefreshPanel.  The panel should be updated in response to events that occur outside of itself.  That part's not a problem.  However, I would like to enable/disable various submenu items in response to some of these events - and that's not working.  The documentation states:
When using
WebMenu supports the rendering of hierarchical menus that can be styled and data bound.  The WebMenu control has server-side and client-side events that can be used.
Toolbox Item: UltraWebMenu
Namespace: Infragistics.WebUI.UltraWebNavigator
',event)">WebMenu
in a WARP Panel, setting certain properties on the server during an asynchronous postback will not take effect on the client. This issue applies to any property that requires submenus to be re-rendered, and occurs because submenus are not refreshed during asynchronous postbacks. In most cases this is not an issue, as property changes that require re-rendering are fairly infrequent. For example, if you set the CheckBoxes property to True or False for the entire menu, during an asynchronous postback, this change won't be reflected on the client until a full postback is called.
Does the above mean that in order to enable/disable submenu items, I must do a full page postback?  Or is there some way to get around this limitation?
Ken
