webdatatgrid template columns
1) need an way to implement TemplatedColumn in wdg.
proteed void Grid_InitializeRow(object sender, RowEventArgs e){if (e.Row != null){TemplatedColumn primary = (TemplatedColumn)e.Row.Items.FindItemByKey("name").Column; // what is an alternative for TemplatedColumnGridRecordItem cellItemPrimary = (GridRecordItem)primary.CellItems[e.Row.Index]; // is this correct?
2) how to implement CellItems in webdatagrid
GridField cellItemfirst = (GridField)first.CellItems[e.Row.Index];
3)find control on webdatagrid
Image secImage = (Image)cellItemSecondary.findcontrol("imgcol");
Hello Arjun,
Please let me know if you still need help with this issue.
Thank you for posting in our forums!
The following documentation provides information on how you can implement a TemplateField in the WebDataGrid:
http://help.infragistics.com/doc/ASPNET/current/CLR4.0/?page=WebDataGrid_Using_Item_Template.html
The following forum thread discusses your second and third questions related to CellItems and FindControl():
http://ko.infragistics.com/community/forums/p/89436/441877.aspx
If you have any further questions or concerns with this, please let me know and I will be glad to help.
