Thanks in advance.
We are using qtp 9 and trying to click on a toolbar button in the ultratoolbar.
We used .NET spy and were able to see some properties like Enabled = true.for all the buttons..
But we are not able to change any value in them.
Is there any way we can click the button in the ultra tool bar.
There are some 8 buttons and we want to clcik on the first button.
We planned to disable the other buttons and keep the first button enabled and use the firevent click in the .net spy for toolbarmanager.
Since we are not able to set the enabled property to false,it is not working for us.
Please help us in this.
Kala
Hi Kala,
While Mercury's QuickTest Professional(QTP) does expose the Object model such that you can manipulate an object if it is absolutely required, it is highly recommended if you need to set a property that we do not explicitly expose through our proxy for QTP, you should have your developer expose a means to manipulate it.
This also coincides with the general practices and expectations of testing products such as QTP that tests the User Interaction (UI) layer of your application. Which is if the state you are trying to test is not attainable via the UI, then there would be no reason to test that state with a UI testing tool.
That being said, it is possible to both access and set public properties of an object through the use of QTP. It will require knowledge of both our NetAdvantage object model, as well as information about the internals of your applications Tool structure, and likely a lot of trial an error testing as there will be no intellisense and QTP is not forgiving. Also to my knowledge, and I could be wrong as this is more about QTP's internal specifics that I am not an expert on, but QTP does not appear to offer a means to access indexed properties directly such as in the case of Tools[0].Key. But most of our collection objects offer methods to allow you to work around this limitation.
For our object model, I can direct you to our Online Help, which should get your through most of the hurdles.
So a script similar to this would be able to set a tool's Enabled property to false:
Is there any toolclick or click events on ultrawintoolbars.buttonTool? All I see is toolclick event on ultratoolbarmanager that passes Infragistics.Win.UltraWinToolbars.ToolClickEventArgs as parameter, but this toolclick method is not accessible to QTP, So is there any UltraToolBarManager.UltraToolbar.Tools(0).click event or similar event that can be used from dev side to expose it to QTP?
thank you
This sounds like it may be a bug, but I am unable to reproduce it, do you have a sample application that demonstrates this happening. Also out of curiosity for the found sToolBarKeyand sToolKey, how do they differ from what was recorded?
Ok. I have found an answer to my issue detailed above of performing a click on a tool item in a toolbar dock area object. Hopefully, this helps someone.
sExpToolText = lcase(trim(replace(sInputValue," ", ""))) 'Get the number of toolbars within the dock area' iNumToolBars = objToolBarDockArea.ToolbarsManager.Toolbars.Count bToolFound = False For iToolBar = 0 to iNumToolBars - 1 Set objToolBar = objToolBarDockArea.ToolbarsManager.Toolbars.GetItem(iToolBar) sToolBarKey = objToolBar.Key Set objTools = objToolBar.Tools iNumTools = objTools.Count For iToolItem = 0 to iNumTools - 1 sToolKey = lcase(trim(objTools.GetItem(iToolItem).Key)) IF qa_eval_condition(sToolKey,sExpToolText, "equals") = True then sToolKey = objTools.GetItem(iToolItem).Key bToolFound = True Exit For End if Next If bToolFound = True then Exit For Next Set objToolBar = nothing Set objTools = nothing If bToolFound = False then SetErrVariables micFail, "Expected ToolBar item: " & sInputValue & " is not found." else oInputObject.ClickToolbarTool sToolBarKey, sToolKey End If
I have a similar issue described above. NetAdvantage - 10.3 TestAdvantage 2010 vol 3.
QTP records the following interaction.
SwfToolbar("_FXCashLadderControl_Toolbars_").PerformToolAction tbmgrToolbar, tbmgrClick, "FX", "AddMultiFXTrades"
However, it cannot play it back.
The toolbar in question is of type - Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea
.GetItemsCount and .GetContent return an empty string.
I am able to get the caption of a control by passing in an index. .GetItem(0) will give me back the correct caption of the tool.
Can you please suggest a way to perform a click on a tool in this toolbar?
Hi Kshireesh,
Perhaps my answer was a bit misleading, in that the Action would change depending on what version of NetAdvantage that you had. The functionality of the Toolbars Manager increased in each subsequent release of NetAdvantage. Early on there were just normal toolbars, then they expanded to include Ribbons, Application Menu, MiniToolbars, NavigationToolbars, etc. These are all different styles of toolbars that can possibly co-exist, on one form. As they can co-exist on one form, and the same tool can exist on each style of Toolbar, the separate actions were necessary to identify what exact tool you were interacting with. Perhaps if you gave me some insight into what version of NetAdvantage that you are using, if you are using the corresponding version of TestAdvantage, ie if your application uses NetAdvantage 2007 Volume 3, are you using TestAdvantage 2007 Volume 3, and maybe describe or include a picture of the tool that you are trying to interact with. Also when in doubt, what action if any is recorded if you use QTP to record against the application.
did you guys find the solution i tried All of the below and could not click on the Tool inside toolbar
All versions of Net/Test Advantage
Normal Toolbar - ClickToolbarTool(oToolbar, oTool)
Net/Test Advantage 2007 Volume 3
Navigation Toolbar - ClickNavToolbarTool(oTool)
