20
Error while using TA 8.2
Hi There,
Using QTP 9.5 with .Net addin and TA 8.2. The app under test uses infragistics 8.2. All was fine for last 1.5 years. Recently I had to reinstall QTP,TA again due to some maintenence. However, Im getting error below. QTP by itself seems to be ok ie recording coordinates but as soon as TA 8.2 is installed, it is not recognising objects. I have tried reinstalling a few times from scratch but I get same error. I had some developers (of the app under test) look at this as well and they think the error is on TA side. Please advise.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Mercury.QTP.CustomServer.CustomServerBase.StopErrorThread(Object o, EventArgs a)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.ComponentModel.Component.Dispose(Boolean disposing)
   at System.Windows.Forms.Control.Dispose(Boolean disposing)
   at Infragistics.Win.UltraControlBase.Dispose(Boolean disposing)
   at Infragistics.Win.ValueListDropDown.Dispose(Boolean disposing)
   at System.ComponentModel.Component.Dispose()
   at Infragistics.Win.ValueList.Infragistics.Win.IValueList.Activate(IValueListOwner owner)
   at Infragistics.Win.UltraWinEditors.UltraComboEditor.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Austin
    Assembly Version: 3.2.0.78
    Win32 Version: 3.2.0.78
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Austin.exe
National.Austin.UI.Main
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/National.Austin.UI.Main.DLL
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
National.Austin.Common
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/National.Austin.Common.DLL
Infragistics2.Win.UltraWinToolbars.v8.2
    Assembly Version: 8.2.20082.1000
    Win32 Version: 8.2.20082.1000
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinToolbars.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinToolbars.v8.2.dll
Infragistics2.Win.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.v8.2.dll
Infragistics2.Shared.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Shared.v8.2.dll
Infragistics2.Win.UltraWinStatusBar.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinStatusBar.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinStatusBar.v8.2.dll
Infragistics2.Win.UltraWinExplorerBar.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinExplorerBar.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinExplorerBar.v8.2.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Design
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.1 built by: SP
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Castle.Windsor
    Assembly Version: 1.0.3.0
    Win32 Version: 1.0.3.5285
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Castle.Windsor.DLL
Castle.Core
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Castle.Core.DLL
Castle.MicroKernel
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Castle.MicroKernel.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Castle.DynamicProxy2
    Assembly Version: 2.0.3.0
    Win32 Version: 2.0.3.5285
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Castle.DynamicProxy2.DLL
Castle.Facilities.Logging
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Castle.Facilities.Logging.DLL
Castle.Services.Logging.Log4netIntegration
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Castle.Services.Logging.Log4netIntegration.DLL
log4net
    Assembly Version: 1.2.10.0
    Win32 Version: 1.2.10.0
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/log4net.DLL
Microsoft.Practices.EnterpriseLibrary.Common
    Assembly Version: 3.1.0.0
    Win32 Version: 3.1.0.0
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Microsoft.Practices.EnterpriseLibrary.Common.DLL
National.Austin.Services.Data
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/National.Austin.Services.Data.DLL
National.Austin.UI.WebServiceProxy
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/National.Austin.UI.WebServiceProxy.DLL
System.Web.Services
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
e_0cml8l
l5zdzgaf
Microsoft.Practices.EnterpriseLibrary.Caching
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Microsoft.Practices.EnterpriseLibrary.Caching.DLL
Microsoft.Practices.ObjectBuilder
    Assembly Version: 1.0.51206.0
    Win32 Version: 1.0.51206.0
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Microsoft.Practices.ObjectBuilder.DLL
Microsoft.Practices.EnterpriseLibrary.Logging
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Microsoft.Practices.EnterpriseLibrary.Logging.DLL
System.Management
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Microsoft.Practices.EnterpriseLibrary.Security
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Microsoft.Practices.EnterpriseLibrary.Security.DLL
National.Austin.Common.Security
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/National.Austin.Common.Security.DLL
Microsoft.Interop.Security.AzRoles
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Microsoft.Interop.Security.AzRoles.DLL
Microsoft.Practices.EnterpriseLibrary.Validation
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/Microsoft.Practices.EnterpriseLibrary.Validation.DLL
Infragistics2.Win.UltraWinTabControl.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v8.2.dll
Infragistics2.Win.Misc.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.Misc.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v8.2.dll
Infragistics2.Win.UltraWinEditors.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v8.2.dll
Infragistics2.Win.UltraWinGrid.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v8.2.dll
National.Austin.UI.StyleManager
    CodeBase: file:///C:/Program%20Files/National%20Australia%20Bank/Austin%20UI/3.2/National.Austin.UI.StyleManager.DLL
Infragistics2.Win.UltraWinMaskedEdit.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinMaskedEdit.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinMaskedEdit.v8.2.dll
Infragistics2.Win.UltraWinListView.v8.2
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinListView.v8.2/8.2.20082.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinListView.v8.2.dll
zklym-8d
c3lrwlnl
16sw1xbo
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Mercury.QTP.Agent
    Assembly Version: 8.0.136.0
    Win32 Version: 9.5.298.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Mercury.QTP.Agent/8.0.136.0__7d38df5e43b1c39a/Mercury.QTP.Agent.dll
MngUtils
    Assembly Version: 8.0.130.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC/MngUtils/8.0.130.0__7d38df5e43b1c39a/MngUtils.dll
CustomBridge
    Assembly Version: 8.0.70.0
    CodeBase: file:///c:/program%20files/hp/quicktest%20professional/bin/custombridge.dll
    Assembly Version: 6.5.132.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Mercury.QTP.CustomServer/6.5.132.0__7d38df5e43b1c39a/Mercury.QTP.CustomServer.dll
Remoting
    CodeBase: file:///c:/program%20files/hp/quicktest%20professional/bin/remoting.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Infragistics2.QTPServer.WinExplorerBar.v8.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202008%20Vol.%202%20CLR%202.0/Bin/Infragistics2.QTPServer.WinExplorerBar.v8.2.dll
Infragistics2.QTPServer.Shared.v8.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202008%20Vol.%202%20CLR%202.0/Bin/Infragistics2.QTPServer.Shared.v8.2.DLL
Infragistics.License
    Assembly Version: 1.0.5005.10
    Win32 Version: 1.0.5005.10
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Infragistics.License/1.0.5005.10__7dd5c3163f2cd0cb/Infragistics.License.dll
Infragistics2.QTPServer.WinTabControl.v8.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202008%20Vol.%202%20CLR%202.0/Bin/Infragistics2.QTPServer.WinTabControl.v8.2.dll
Infragistics2.QTPServer.Win.v8.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202008%20Vol.%202%20CLR%202.0/Bin/Infragistics2.QTPServer.Win.v8.2.DLL
Infragistics2.QTPServer.WinEditors.v8.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202008%20Vol.%202%20CLR%202.0/Bin/Infragistics2.QTPServer.WinEditors.v8.2.dll
Infragistics2.QTPServer.WinDropDown.v8.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202008%20Vol.%202%20CLR%202.0/Bin/Infragistics2.QTPServer.WinDropDown.v8.2.dll
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
v9vq6_mv
Infragistics2.QTPServer.WinMisc.v8.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202008%20Vol.%202%20CLR%202.0/Bin/Infragistics2.QTPServer.WinMisc.v8.2.dll
Interop.NETDISPATCHSERVERLib
    CodeBase: file:///c:/program%20files/hp/quicktest%20professional/bin/Interop.NETDISPATCHSERVERLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Parents
  • 6729
    Please verify TA configuration by recording and replaying on the TestAdvantage samples that get installed with the product. Do you get the same problem?
    Another thing to verify is installing the .NEt Add-in from QTP, do you have this installed after rebuilding your system?
    Ammar
Reply Children
No Data
