To use TestAdvantage with UFT 11.5 you need to install patch UFT_00001.
Let me know if you have any questions with this matter.
Updated software to UFT 11.51 and confirming that infragistics is in work
+pavan
Hi Alan,
I had installed TestAdvantage 2013.2 version (free trail). When i checked the "Test Automation Settings Utility", it all displaying as WinObjects.
In my case the objects are getting identified as SwfObject, SwfComboBox, ...etc. I already have .NET framework 4.0 installed (Client Profile & Extended) in my machine. Do I need to update this with any of the patches, since I am still unable to identify that object which is displayed in the drop down box.
Please suggest me.
Regards, Sandeep
I tried installing UFT_00001.exe patch, but no luck.
The ribbon panel in which the object resides, is kind of a drop down box.....from where I need to select the item. During the record, the item is not getting identified.
please provide me the solution.
Sandeep
Awaiting your reply at the earliest. As I mentioned in my earlier posts, that I am using Test Automation Version Free utility. I even have othet options as 13.2CLR4.0. Currently I have selected Version Free option. I also mentioned that I am using .NET framework version 4.0 in my machine.
Could you please let me know the exact net advantage version & patches if any, that I need to use?
Sandeep,
The application that is being tested must have been built using the version of NetAdvantage that corresponds to the version of TestAdvantage that you are using. You say that you have selected TestAdvantage 13.2CLR4.0 Version Free. So your application has to have been built using NetAdvantage 2013 volume 2 with version-free assemblies. Let me know if you have further questions.
Hi Michael,
Y'day night I replied back to your answer from my mobile, seems unfortunately did not get posted.
The link which Alan had provided me in his earlier reply, accessed the same link and installed the test advantage. During installation, it asked me to select an option out of 3 options...1. Disable all versions, 2. 13.2CLR4.0, 3. Version Free. I had selected version free option. Please let me know in detail if any thing else need to be installed, since its becoming difficult to identify that object by any means.
I'm not sure I understand what you are doing. I don't think you need to install anything else. You had asked which version of NetAdvantage you need and I explained that since you are using TestAdvantage 13.2 version-free, you need to verify that the application you are testing was built with NetAdvantage 13.2 version-free assemblies.Are you able to determine which version of NetAdvantage was used to build the application you are testing? Can you confer with your developers about this?
