80
WebImageViewer SlideShow
I need to use WebImageViewer in two different way:
the first is the classic one with prev and next button and there are not problem...
The second is the classic slideshow, an automatic projection of all images with a delay and with shading effect...
I have thought to a client side timer... but with no a good result
Can I do this with the WebimageViewer?
I have an incident too .. about this request... I'm just a bit hurry...
Thank you in advance...
Parents
No Data
Reply
  • 7694
    Suggested Answer
    You can use the Java Script method navigateNext () with this method  you can navigate to next item.  Also you can use the method setInterval(code, delay) and set delay  of execution  .In the WebImageViewer1 you can set the property  Type=NextItem in ScrollAnimation tag. For starting of the slide show you can attach  this code in onload event of the body tag.
    Please take a look at the attached sample code below:
            function SlideShow() {
                var viewer = $find("WebImageViewer1");
                viewer.navigateNext();
        </script>
    </head>
    <body onload="setInterval('SlideShow()', 1000)">
        <form id="form1" runat="server">
        <asp:ScriptManager ID="ScriptManager1" runat="server">
        </asp:ScriptManager>
        <div>
            <ig:WebImageViewer ID="WebImageViewer1" runat="server" Height="150px" Width="500px">
                <ScrollAnimations Type="NextItem">
                </ScrollAnimations>
                <Items>
                    <ig:ImageItem ImageUrl="http://samples.infragistics.com/2008.2/webfeaturebrowser/images/WebImageViewer/image2.jpg" />
                </Items>
                <Items>
                  http://samples.infragistics.com/2008.2/webfeaturebrowser/images/WebImageViewer/image3.jpg" />
                </Items>
                <Items>
             http://samples.infragistics.com/2008.2/webfeaturebrowser/images/WebImageViewer/image6.jpg     " />
                </Items>
                <Items>
      http://samples.infragistics.com/2008.2/webfeaturebrowser/images/WebImageViewer/image5.jpg           " />
                </Items>
            </ig:WebImageViewer>
        </div>
        </form>
    </body>
    For more information you can  take a look  at the links below:
    http://www.elated.com/articles/javascript-timers-with-settimeout-and-setinterval/
    http://samples.infragistics.com/2009.1/WebFeatureBrowser/Default.aspx
    http://help.infragistics.com/NetAdvantage/ASPNET/2009.1/CLR3.5/
    Hope this helps.
    Ivan Baev
    Developer support team
Children
