Hello I do the following:
1. I have a WebDialogWindow.
2. In the WebDialogWindow resides a WebDataGrid.
3. I load a dataset into a WebDatagrid and remove the hidden status.
The WebDatagrid has more columns then the width of the WebDialogWindow. I use the scrollbar to slide to the rightmost column and I do a sort. This works fine, however if I try to set a summary the scrollbar bounces back which makes it impossible to select a summary value. It looks like the drawing of the menu item stretches the width which the scrollbar to reposition.
It works fine when I put compatibility mode off but the problem is if I do that the infragistics WebSplitter on my page will not work anymore and no one has a solution for this.
Hi Blikman,
Could you possibly attach a sample that reproduces this issue? It does sound like a bug. If you attach a sample here, I can open a bug and take a look. Another option is to contact Developer Support and work with them to create a sample and submit a bug.
regards,David Young
the aspx:
="True">
="NotSet">
="10">
="Single">
="~/Images/grid.png">
the cs:
private void ViewData()
if(UltraWebTree1.SelectedNode == null) return;
if (UltraWebTree1.SelectedNode.Parent != null)
WebDataGrid1.ClearDataSource();
Session[
"data"] = logic.ConvertCsv(dataDirectory.FullName + "\\" + UltraWebTree1.SelectedNode.Parent.Text +"\\"+ UltraWebTree1.SelectedNode.Text+".csv");
WebDataGrid1.DataSource = ((
DataTable)Session["data"]);
WebDataGrid1.DataBind();
WebDialogWindow1.Header.CaptionText =
" Bekijken : " + UltraWebTree1.SelectedNode.Parent.Text +"/"+ UltraWebTree1.SelectedNode.Text;
WebDialogWindow1.WindowState = Infragistics.Web.UI.LayoutControls.
DialogWindowState.Normal;
Contacting support is not an option since your customer support is only available around midnight (european times Amsterdam)
That works , thanks.
Can you also take a look to my last problem?
http://community.infragistics.com/forums/t/53036.aspx
Hello Blikman,
Thank you for sharing the code snippet.
I was able to reproduce the issue with IE8.
I solved it by setting the EnableRelativeLayout property of the ContentPane
<ContentPane EnableRelativeLayout="true" >
http://help.infragistics.com/NetAdvantage/ASPNET/2010.3?page=Infragistics4.Web.v10.3~Infragistics.Web.UI.LayoutControls.LayoutPane~EnableRelativeLayout.html
Please let me know if you need further assistance regarding this.
