290
Column Chart with Data Points
I have a column chart that I need to display data points on.  I'm not sure if this is the correct terminology so I'm including the chart I have in Excel.  I need to be able to place the little triangles on the columns to represent an event that happened in that month.  Make sense.
Parents
  • 26458
    This isn't really supported out of the box. The only series that can display the triangle icons is the scatter series, but that one needs a pair of numeric coordinates and plots on numeric x and numeric y axes. The triangles would have to be added on manually by using FillSceneGraph event. You'd have to calculate the spot where you want the triangle to appear, create a Symbol primitive, set its icon and color and add it to the scene.
    Symbol s = new Symbol();
    s.point = new Point(x, y);
    s.icon = SymbolIcon.Triangle;
    s.PE.Fill = Color.Blue;
    e.SceneGraph.Add(s);
    Finding the x and y can be tricky. You have to loop through the SceneGraph to find the 2 Box primitives with matching Row and put the symbol between them.
Reply Children
