Hi
If anybody know this issue please help me out.
Regards
Sheeraz
Has this issue been resolved? I have a WebUpload control in a WARP panel and it dissapears after a warp refresh. I am using NetAdvantage Select 2011 Volume 1 SR 2158.
Thanks!
Hi Abhishek,
The issue is fixed and now it should be included for the next Service Release. I suppose it should be ready soon.
Miro Hristov
Hi Miroslav,
I'm currently using Infragistics v 11.1 , do we still have the issue of WebUpload with AsyncPostBack.
Thanks in Advance
Abhishek
Hi sheeeraz001,
1. About WebUpload control in Update Panel - yes this is bug and we will fix this for the next Service Release. Only I want to tell you that file upload control uses AJAX and updates its information async. So if it is possible for you to set WebUpload outside the update panel - this is also solution for now. Also when we fix this bug - for instance if you have uploaded 1 or 2 files and when you make the postback the control just will be re-initialized and will be at the initial state so you should not expect to be with the same information and state before the async request is made. For instance you are uploading one file and meanwhile you make async postback(and fileupload is inside update panel) Then the whole content will be updated, includeing file upload - the uploading of file will be interrupted and will be shown the upload button only(initial state).
2. About this case I am not sure what exactly you want to make. I can only suppose that when file upload is finished you want to update data source and re-bind WebDataGrid. If this is the case you should update datasource from the client - to attach to client side event of the WebUpload for file uploaded - FileUploaded and when file is successfully uploaded to update the data source. It depends on type of data source - if it is local you can update it locally and rebind WebDataGrid otherwise you can make request to update it and you should rebind datagrid to see the changes. This is only one case - I am not sure what exactly is your so please specify more information.
Thanks,Miro Hristov
