I have implemented Automatic load on demand by refering a sample example from Infragistics online sample website. However when i am expanding couple of rows three to four times after that it is not collapsing. For example take a scenario Expand and collape first 5-6 rows couple of times and after that keep all the rows in expand mode than try to collapse the rows starting from first row, it won't collapse. The same problem i found in Infragistics sample website also. http://samples.infragistics.com/aspnet/Samples/WebHierarchicalDataGrid/Performance/LoadOnDemand/Default.aspx?cn=hierarchical-data-grid&sid=b97e3a58-a6c2-4327-b289-de68335559f4
Please look into this issue.
Mits
The upgrade to the version: 20111.2178 solved the problem!!
Thank you Troy for your support
Alexandre
What i meen to say was "older version"
Thanks for prompty reply!
By your answer i can assume that your sample is in a earlier version, because i can reproduce the same problem!
If you go to your sample with IE 9.0: http://samples.infragistics.com/aspnet/Samples/WebHierarchicalDataGrid/Performance/LoadOnDemand/Default.aspx?cn=hierarchical-data-grid&sid=b97e3a58-a6c2-4327-b289-de68335559f4
The Versions that i am working with:
11.1 --> 11.1.20111.2020
11.2 --> 11.2.20112.1019
I Will try with the new versions!
Hi aandrade09,
This was a development issue that was since corrected. Can you tell me the specific steps you are taking to reproduce this issue? I have tested this with 11.1 and 11.2 and am unable to reproduce this behavior. Also, I have updated my assemblies to the latest service release. For 11.2 and 11.2 the latest service release will bring you current as follows:
20111.2178
20112.2086
Please let me know if I can be of any further assistance regarding this matter.
I would like to know if there is some development about this problem!
Your sample continues with the problem!
I'm using IE 9, and i tried with infragistics versions: v11.1 and v11.2
Thanks in advance,
