I'm using WebDataMenu control (11.1.20111.1006)
When i update (change menu items) on serverside and update UpdatePanel where menu is placed data menu is not rendering correctly. Instead of horizontal, scrooling menu i receive items in rows, all visible and no slider (slider is missing). It seems that in chrome even after first loading i can see how the js script hides menu items, but after updating part of code is not firing probably.
Could you please have a look and check what is wrong here.
Control setup:
<asp:UpdatePanel UpdateMode="Conditional" runat="server" ChildrenAsTriggers="true" EnableViewState="false" ID="TopMenuClustersUpdatePanel" >
<ContentTemplate>
<ig:WebDataMenu ID="TopMenuClusters" EnableScrolling="true" runat="server" MaxDataBindDepth="1" AutoPostBackFlags-ItemSelected="Off" ScrollingSpeed="VeryFast" EnableAjaxViewState="false" >
<ClientEvents Initialize="IE7ZIndexAdjust" ItemUnhovered="removeSelected" ItemSelected="clusterSelected" />
<GroupSettings Orientation="Horizontal" Width="750px" Height="100%" EnableAnimation="true"
AnimationType="OpacityAnimation" AnimationDuration="200" />
<DataBindings>
<ig:DataMenuItemBinding DataMember="Table" ToolTipField="Name" ValueField="ID" KeyField="ID" TextField="Code" Depth="1" />
</DataBindings>
</ig:WebDataMenu>
</ContentTemplate>
<Triggers>
<asp:AsyncPostBackTrigger ControlID="GroupsDropDown" EventName="SelectionChanged" />
</Triggers>
</asp:UpdatePanel>
Hello Bartlomiej,Please let me know if you had the chance to test our new service release and verify if the issue is resolved./;
Hello,I have investigated your issue and, I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 90688. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I will leave this case open and update you with any new information after the review. You can also continue to send updates to this case at any time.
You can view the status of the development issue connected to this case by going to the “My IG” tab on our website, hovering to the "My Support Activity" dropdown and selecting the "Development Issues" tab.
Please let me know if you need more information.
Hi Nicifor,
I think that you still don't understand the scenario i have.
Your code works fine without update panel but it is doing FULL POSTBACK and i need PARTIAL POSTBACK as my application is fully ajax.
So i need to use Update Panel. Please tell me where i can send file with compressed source so you can see my issue in chrome.
And please tell me why it works all other browsers (ie, ff, opera) and only chrome in my scenario fails.
I'm almost sure that it is a bug, but if you are going to tell me that i can't use update panel i think that our conversation is useless.
Hello,Please let me know if you need furthe assistance with this issue
Hello,Please see the attached sample. The UpdatePanel is commented and the event for changing the value of the first element of the menue when value of dropdown is changed behaves as expected.
