As u can see in attached file, I need to have a chart but with 2 Y-axis. One chart is the temperatures for different dates and other one is for energy for different dates, but I neef them on same drawing.
You know ho I can have both charts in same drawing, one X axis for different dates and 2 Y-axys: one on left for energy (MW values) and one Y-axys on right side for the temperature values ??
1/What s simplest kind of chart, and if you have a sample, that ll be great
2/ do u know how to put one axis on left and one on right, if not I guess I will have to tell them it s not possible and we ll just have both axys one next to the other
In the drawing attached, actually the temperature axis is for 3 datacolumns, and the BesoinPrevue axix is for energy column, but a sample for two is fine, instead of four, one for a temperature column and a second axis for energy column. The x axis is same for dates
Thanks a lot
oups just read ur code behind sample, it s really n"Y2" ok then I appreciate ur help :)
thanks a lot Maya, i gues u mean: both properties = "Y-Axis" rather nthan one as "y_axys" and the other "Y2_axis"
sorry not very familiar with your charts (yet) :) :)
Hello rtutus ,
You would need to use a composite chart and add the new axis like shown in a sample from out sample browser:
http://samples.infragistics.com/aspnet/Samples/WebCharts/Display/Composite-Charting/Multiple-Chart-Axis/Default.aspx?cn=chart&sid=ce16fadb-c07d-4848-9436-f1de26c1fc4f
As you can see in that sample there’re 4 custom axises whose OrientationType property is set to “Y_Axis”. You could use the same code and use 2 custom axis 1 with OrientationType=”Y_Axis” and one with OrientationType=”Y2_Axis”.
I’m also attaching a sample with this but with the axis added from the code behind. Let me know if you have any further questions regarding this.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
