40
Infragistic 8.2 to 11.1 migration
I have a VS 2008 (Framework 3.0) Solution that needs to be migrated to VS2008 with Framework 4.0,so i am using trial version of infra 11.1 ,first i migrated to VS2010 and by using version utility 11.1 i migrated to 11.1 now,
1.while migrating which CLR version i should choose its showing CLR 2.0 as default,
2. when i choosed 4.0 and migrated my solution i am getting following error
   a."Object reference not set to an instance of an object" in all the infragistic controls     when  viewed in designer page.
   b.The images are not loaded from ig_common\images folder,will this loation change after the migration..
