I have a WebSplitter [Infragistics35.Web.v11.1, Version=11.1.20111.1006] placed in a contentpage. When i resize the SplitterBar once my IE8-Browser hangs. I could not do anything with the webpage. I also found no errormessages. The same action in FireFox works fine.
The code is:
<ig:WebSplitter ID="SplitterBrowser" runat="server" Height="95%" Width="100%" DynamicResize="True"> <panes> <ig:SplitterPane runat="server" Size="25%"> <Template> <ig:WebDataTree ID="TreeDirectories" runat="server" Height="100%" Width="100%" EnableConnectorLines="True" onnodeclick="TreeDirectories_NodeClick" onnodecollapsed="TreeDirectories_NodeCollapsed" onnodeexpanded="TreeDirectories_NodeExpanded" SelectionType="Single" StyleSetName="Windows7"> <AutoPostBackFlags NodeClick="On" /> <NodeSettings ParentNodeImageUrl="~/images/SSL/FolderOpen.gif" /> </ig:WebDataTree> </Template> </ig:SplitterPane> <ig:SplitterPane runat="server" Size="75%"> <Template> Here is a WebDataGrid </Template> </ig:SplitterPane> </panes> </ig:WebSplitter>
The WebSplitter is not content of a UpdatePanel.
Could anyone please help me?
Thank you
Martin
Hi Martin,
I'm glad you solved your issue. If you have any other questions, please let me know.
Hi Nikolay,
I think i have found the problem. It is not the SplitterBar from Infragistics. The problem is a third-party-CSS-library we use. That causes the freeze.
Sorry, that i believed it is caused by the WebSplitter.
In this case, can you please provide me with a small isolated sample reproducing the issue in order to be able to investigate this further. Thank you.
Hello Nikolay,
thank you for your sample. It works fine for me. I compared all settings with my app but the resize also freezes in IE 8. I changed compatibiliy mode but without success.
The last row in Fiddler2 i get is:
.../ig_res/Default/images/igspl_splitvertpressed.gif
and after this i must stop the debugger because i cannot do anything more in InternetExplorer
Hello Stumpy74,
If you have any questions, please do not hesitate to ask.
