Step#1 - A user sees a Infragistics 11.2 webdatagrid in batch mode.
Step #2 - A user clicks on a cell to edit some data.
Step #3 - The user enters some text on the keyboard and hits enter.
Step #4 - The user tries to keep typing but the edit mode has exited. Is there a setting to keep the cell in edit mode and save the cr/lf from the pressed enter key in the data?
p.s. c#, .net 3.5, webdatagrid, BatchUpdating="True"
I had to use BOTH to make it work correctly. Thanks so much. Also here is where I wired up the client event for anyone else looking at this solution:
<CellEditingClientEvents ExitingEditMode="gridMedications_CellEditing_ExitingEditMode" />
</ig:CellEditing>
as far as I can understand you don't want to exit from edit mode after press Enter.
Option #1: Handle ExitingEditMode client event and cancel it if Enter is pressed:
function WebDataGrid1_CellEditing_ExitingEditMode(sender, eventArgs) { if (eventArgs.get_browserEvent().keyCode == 13) { eventArgs.set_cancel(true); } }
Option #2: Use TextBoxProvider, this will allow you to enter multi line text. I recommend you to use this option
<EditorProviders> <ig:TextBoxProvider ID="WebDataGrid1_TextBoxProvider1" EditorControl-TextMode="MultiLine"> <EditorControl ClientIDMode="Predictable" ></EditorControl> </ig:TextBoxProvider> </EditorProviders>
Let me know if you need further assistance
