I'm looking at an issue I can duplicate in IE7 and IE8 with Compatibility View. The page has two WebDataGrids insied a WebGroupBox that is on an UpdatePanel. EnableDataViewState is true. After binding a datasource (DataSet from SQL) to the grids, the iexplorer.exe process shows CPU activity when the page is sitting idle: no user interaction. It never seems to stop: I've waited up to an hour and the process shows CPU activity in TaskMan and ProcExp. Oddly, ProcMon doesn't show any disk, registry, network, or thread IO from the same process. In IE8, if you disable compatibility view the page laods and CPU returns to 0% until you interact with the page. I'm using version 11.1.20111.2158. The same issue occurs on other pages in the application that have WebDataGrid in WebGroupBox on UpdatePanel. Some grids have filtering and other don't but all have EnableDataViewState=True and cell selection. Example ASPX snippet.
="1008px">
="server">
="box">
="False"
="True">
No Waves Found
="100%">
="true">
="300px">
="OnRight">
Ticket :
="100">
="clearDropDowns()"/>
I checked my history and on 8/14/12 confimred I could not reproduce the issue with 11.2.20112.2159. I have since upgraded to 12.1.20121.2209 and there are no reports of the issue occuring. Additionally, we upgraded the impacted users to IE8 and made sure they were not using compatibility mode as the IE8 engine is significantly faster with some operations. That might not be feasible in your environment; however, using the latest SR for you components should resolve the base issue.
I'm would like to know if you guys came up with a fix/workaround for this issue. I came across the same scenario using IE with compatibility mode. It's the WebDataMenu that is causing the issue (event/listener). Once I removed the menu off the page, things turned better.
Thanks.
Hello dc06663,
My apologies, your case should be visible now.
How do I view this ticket? I don't have any support cases assigned to my logon.
Thank you for the sample. I was able to reproduce this issue (indeed it seems to occurr only under very specific circumstances).Therefore, I have asked our engineers to examine the matter further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 116256. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
Your support ticket id regarding this matter is - CAS-94616-LW7TZD. Feel free to continue sending us updates regarding this issue at any time.
You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
Please let me know if you need more information.
