I am attempting to set up an instance where, if a parent node is checked then the children are checked and if the parent is unchecked the children should be unchecked.
I assume this is done on the client side.
Can I get some assistance with a script?
Hi Daryl,
You can refer to this thread regarding the matter - http://ko.infragistics.com/community/forums/p/53859/313719.aspx.
On this line
function ClickHandler(sender, args) { isChecked = args.get_item().get_row().get_cell(0).get_element().children[0].checked;I get an error message stating that "Microsoft JScript runtime error: Object doesn't support property or method 'get_item'
Hello Daryl,
Provide me with an isolated sample project and I will be happy to assist you finding what is causing the issue.
Could you try what I sent you but wrap it in a webtab? Could that have an effect.
Okay, I have given up on this and gone to using the built in check boxes.
Now I need to use autocheck, which works, but, when I click a child I don't want the parent changed. I only want it to work when I click the parent then update all the children.
You could achieve such behavior using the following script for NodeChecking client side event:
var checkState = 0;
function WebDataTree1_NodeChecking(sender, eventArgs) {
var node = eventArgs.getNode();
checkState = (node.get_checkState() == 0) ? 1 : 0;
setChildrenCheckState(node);
function setChildrenCheckState(parentNode) {
if (parentNode.hasChildren()) {
for (var i = 0; i < parentNode.get_childrenCount(); i++) {
parentNode.get_childNode(i).set_checkState(checkState);
if (parentNode.get_childNode(i).hasChildren()) {
setChildrenCheckState(parentNode.get_childNode(i));
In order for this to work, you should set EnableAutoChecking to false.
Let me know if you have any questions regarding the matter.
You sir, Are my hero.
Thanks!
I'm glad I could help.
Feel free to contact me if you have any further questions.
