After upgrading to Version=13.2.20132.2077 the grid column headers can no longer be dragged into the Group Area of the Hierarchical Data Grid.
Is this a known issue? Has anyone else come across this issue?
As we have an imminent release which relies on this behaviour, we require an quick resolution to this issue.
The application is developed in Visual Studio 2010 using the .Net 4.0 framework.
We have tested this against various browsers and it seems to be a consistent issue in all the browsers.
No code was altered, only the IG libraries were upgraded.
In the previous release, Version=13.2.20132.2028, this behaviour functioned correctly.
Hello Tom,
This issue seems to occur when the ColumnMoving behavior is enabled.
I have logged a new development issue regarding this with number 167786.
I’ve also opened a private case for you with number CAS-133557-D5F0G2 so that you may track the state of the development issue.
You can view the status of the development issue connected to that case by selecting the "Development Issues" tab when viewing this case on the web site.
I’ll update you via the case with any new information after the review. If you need any additional information please
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
Hello Maya,
Further to my earlier reply, please find a sample attached, replicating the issue.
Thanks and regards.
Tom
Our scenario is much more complex.
Also note that we have all the behaviours switched on.
I will try and see if I can produce a sample. Unfortunately the sample will have to be as close to our implementation to give you a good
comparative example.
Thanks.
Hello JJB ,
I’ve tested this in a basic scenario where the grid has only Grouping enabled:
<ig:webhierarchicaldatagrid id="WebHierarchicalDataGrid1" runat="server" height="350px"
width="400px">
<GroupingSettings EnableColumnGrouping="True">
</GroupingSettings>
</ig:webhierarchicaldatagrid>
However in this case the group by worked as expected. The columns can be dragged to the group area and when dropped group the rows by the column values.
I’ve attached the sample I used to test this for your reference.
Does this issue reproduce only in more complex scenarios? It would be helpful if you could describe the exact scenario and steps in which this reproduces or send an isolated sample that reproduces this so that we may look into this.
I’m looking forward to your reply.
