How could I implement a control like the NumericUpDown to embed it in a column ?? Where I cand find information about that?
I'd like use it for deal with UltraGridColumn and percentages.
Thanks in advance.
So you need to use the CellChange event of the grid, rather than the ValueChanged of the NumericEditor control.
You cannot rely on the events of the EditorControl to fire when they are used as the editor in the grid. The control simply provides a clone of the editor that the grid should use along with many default properties, but from that point the grid is generally responsible for handling all events and input.
-Matt
I am attaching UltraNumericEditor to the grid column using EditorControl property it works fine, i have attached ValueChanged event which is not getting fired when i click on the spin button, but the same thing is working when i placed UltraNumericEditor control on the form ,
where am i doing wrong?
could you please help me on this?
UltraNumericEditor numericEditor = new UltraNumericEditor( );
numericEditor.Nullable = false,
numericEditor. MinValue = 0 ;
The easiest way to get a spin button in a grid cell is to use an existing editor control like UltraNumericEditor. Just put an UltraNumericEditor control on the form with the grid.From there you have a couple of options.
1) Set SpinButtonDisplayStyle on the UltraNumericEditor. This will give you a built-in spin button which spins the value based on the mask. You can then set other properties like SpinButtonAlignment, SpinWra, and SpinIncrement.
2) Use the ButtonsRight or ButtonsLeft collection to add a SpinEditorButton and handle the EditorSpinButtonClick event and change the value of the cell yourself.
Either way, you attach the control to the grid column via the EditorControl property.
