Let's say I have to display green button icon for column value "1", yellow for column value "2" and red for "3" . I have two requirements
1. Column shows both value and its associated icon. ie. Column value shows "1" <green button icon>, "2" <yellow button icon>, "3" <red button icon>
2. Columns shows only the icon representing the value
Questions:
a. From reading the forum, valuebasedappearance seems to help me achieve both requirements very easily. Is that correct?
b. How would I achieve sorting of the columns in requirement #1 and requirement #2 ?
Ok, I've the same problem with images of all valuelists in all grids in my project since I've made the upgrade to hotfix version 8.2.20082.2121.
If I set an Image, for example, in the field ValueListItems(0).Appearance.Image = My.Resource.SomeImage the result image appears like streatched and don't mantein his original sizes.
Notice that i've not used the imagelist, but simply an image that is in My.Resource
I resolved by filling the properties ImageBackground instead of Image, with field ImageBackgroundStyle setted to "Centered".
But I've created many grid that use Image field to specify an image, and worked fine before the hotfix upgrade.
There is a way to solve my problem? There is some properties that can set the style of an Image (not an ImageBackground)?
Thank you in advance
Stretching of the image is not the same issue at all. The original issue reported in this thread has to do with the corruption of the colors of the image.
I beleive there were some changes made to the sizing of images in a cell so that images maintain their aspect ration when they are resized. If this is causing a problem, you should Submit an incident to Infragistics Developer Support so they can check it out.
