I started localizing UltraWinGrid resources but in the FilterRow one nasty "Custom" refuses translation.
The Status column has a custom filter. What is the name of that text?
We are using v11.2.
Thank you
Burkhard
Hi Burkhard,
Thank you for the clarification. I was able to reproduce this and it seems that there isn’t a way to localize this text using the SetCustomString method. I have logged internal development issue for this in order to ensure that it will get resolved and I am attaching a sample with a workaround, since you are using an older version, which no longer has service release support. The workaround is simple, it uses the CreationFilter interface in order to change the text of the element that displays the filter.
Please let me know if you have any additional questions.
Hi Ditimar,
thank you for your reply. Here ist the screen shot:
In this case the filter is set by code (show everything in the range and including strFilterVon-strFilterBis):
public void SetFilter(EFeldsemantik eFeldsemantik, String strFilterVon, String strFilterBis) { ColumnFilter cf = gridC.DisplayLayout.Bands[0].ColumnFilters[KeyFromSemantik(eFeldsemantik)]; cf.ClearFilterConditions(); if (!StringEx.IsNullEmptyOrSpace(strFilterVon)) cf.FilterConditions.Add(new FilterCondition(FilterComparisionOperator.GreaterThanOrEqualTo, strFilterVon)); if (!StringEx.IsNullEmptyOrSpace(strFilterBis)) cf.FilterConditions.Add(new FilterCondition(FilterComparisionOperator.LessThanOrEqualTo, strFilterBis)); }
RegardsBurkhard
Thank you for posting in our forums.
I am unable to find how to add this filter to the grid. When I add a custom filter it simply displays the value I am filtering on and the filter icon. I can’t get the grid to show the “Custom” text. Please provide me with a small sample where this text is displayed and I will be glad to assist you further with this issue.
Thank you for your collaboration.
I am looking forward to hearing from you.
