370
Can't hide a button on my ultratoolbarsmanager
I'm trying to hide a toolbarbutton on my ribbon using
toolbarmanager.Tools.Item("buttonkey").SharedProps.Visible = False
also tried
toolbarmanager.Ribbon.Tabs("tabkey").Groups("groupkey").Tools("toolkey").SharedProps.Visible = False
but it only disables the button and doesn't hide the button. How can I solve this?
Regards
  • 34810
    Verified Answer
    Hello Reychler,
    In order to be able to actually hide the tools in the Ribbon part of the UltraToolbarsManager, you need to first set the Office2007UICompatibility property to "false." This property defaults to true, and by setting it to false, you are designating that you should not ignore values that are not compatible with the Microsoft Office 2007 Ribbon look and feel. Since it defaults to true, directly hiding Ribbon tools is not supported, and they will be marked disabled instead.
    For a full list of what this Office2007UICompatibility property controls, see the following article: https://ko.infragistics.com/help/winforms/wintoolbarsmanager-using-microsoft-office-2007-ui-capabilities.
    Sincerely,
    Andrew
    Software Developer
