4032
WinTimeLineView scrolling
Does somebody know if the feature from following link is implemented. I can not found the request under "ideas" and can not found any improvements in the release notes up to volume 2017.2 either.
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/89137/winganttview---scroll-bar-doesn-t-scroll-range-set-in-ultracalendarinfo
I'm not able to adjust the scrollbar to be usefully if my range ist just 1 day (MaxDate = MinDate = My current date).
I'm using UltraTimeLinkeView togehther with UltraCalendarInfo and have something like appointments just within one current date. Perfect for me would be if I can set the min-max range from 0:00 current date until 12:00 the following day and the scrollbar should consider this range e.g. if I move the scrollbar handle to the very right end, the range should be visible 12:00 following day.
Any ideas how to achieve that?
I have also tried to setup logical day and offset, but no success. I'm using volume 2016.2 at the moment.
Thanks for any help.
Markus
  • 29105
    Hello Markus,
    A "ScrollMode" property, to achieve this requirement, is considered to be a new product idea. You can suggest new product ideas for future versions (or vote for existing ones) on our ideas page.
    Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it.   You can also link back to this thread for additional details.
    Thank you in advance to submitting your product idea.
