How can I add a check box in a Column Header?
HOWTO:How do I add a CheckBox to a WinGrid column header?
This (http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4883) is exactly what I'm looking for.
Unfortunately, the sourcecode doesn't compile anymore with the current version of Wingrid.
Is it possible to update the sourcecode ?
Thanks in advance,
Kind regards
See also
http://news.infragistics.com/forums/t/10250.aspx
Why doesn't is compile? It works fine for me. You have to change the project references, of course, because the sample is using v5.3 of NetAdvantage. So you will need to update the project either manually or using the project upgrade utility.
I need exactly the same thing with 7.3 , its not workling
Could you be a little more specific? What's not working? What's the problem?
