I installed the Platform and the Version Utility for version 2020.1. However, when I go to upgrade my solutions, 2020.1 is not available as an option in the volume list. CLR Version 4.5 is listed, but changing to it still does not show Windows Forms 2020.1
Could it be because during the install the following errors appeared? Even though it said that the install was complete and it shows up as an app in Windows.
02:40:36: Setting up download of Infragistics_WinForms_20201.msi02:40:36: Beginning download of Infragistics_WinForms_20201.msi02:40:56: Error downloading Infragistics_WinForms_20201.msi. Review the log file for details.02:40:56: System.UriFormatException: Invalid URI: The URI is empty. at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind) at System.Uri..ctor(String uriString) at Infragistics.Wrapper.Interface.Utilities.DownloadExecutionManager.downloadWork()02:40:56: Setting up download of Infragistics_WinForms_20201_NuGet.msi02:40:56: Beginning download of Infragistics_WinForms_20201_NuGet.msi02:40:56: Error downloading Infragistics_WinForms_20201_NuGet.msi. Review the log file for details.02:40:56: System.UriFormatException: Invalid URI: The URI is empty. at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind) at System.Uri..ctor(String uriString) at Infragistics.Wrapper.Interface.Utilities.DownloadExecutionManager.downloadWork()
Hello Sam,
Platform installer is a tool for online install of our products. The tool downloads all selected packages, and installs them. The errors posted and the screenshot indicate that the download has failed. Please re-run the installation with internet connection, and the issue should be resolved.
In case the machine you are installing is behind a firewall or does not have internet connection, you can check the following guide for offline installation.
https://ko.infragistics.com/community/blogs/b/engineering/posts/installing-infragistics-ultimate-without-an-internet-connection
Should you have any further questions, please let me know.
Sincerely,
Tihomir TonevAssocaite Software DeveloperInfragistics
