Hello Guys
I have grid with ultracombo in grid in column 1
How to fill the column 2 from ultracombo column 2
Thanks before
Hengky
www.infragistics.com/.../creating-a-dropdown-list-in-a-grid-cell-whose-list-values-are-dependent-on-another-cell
Do you mean you would like to change the cell text when a combobox in another cell is changed?
You can use UltraGrid’s CellChange event to know when the combobox is changed and update the text of another cell on the same row.
I have created a sample for you.
6136.WindowsFormsApp1.zip
Can you please take a look at the forum post below to see if your problem is resolved there?
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/121658/wingrid-and-winultracombo
