Hello fellows,
I have a simple Column Chart bind to a simple datatable, with Two columns, 1. DepartmentName 2. Total. Department name has Lables whereas Total has the data. I want to display data value of each bar/ Department along with the Legends. When I use the following Syntax, i get the last Data value for each Legend
legend.FormatString=<ITEM_LABEL> (<DATA_VALUE:00.00>
Is it possible to Display Data Values in the legend for column chart.
Thank you for the update. I setup a sample of UltraChart and when I set the legend.FormatString to "<DATA_VALUE>” I am also getting the same behavior, only last data value is showing up in the legend.
I logged a development issue 271065. I also opened a private case for you so that I can link it to this development issue. This way you will be notified automatically when the development issue is updated.
The case number is " CAS-208510-Z5Y6G4". You will see it located here: https://ko.infragistics.com/my-account/support-activity
Let me know if you have any questions regarding this matter.
Thank You Jain for quick response.Yes I'm beginner and Ultrachart is easy to bind with database/ datatable then dataChart.
Sorry for the typing mistak here is my correct code:
UltraChart1.Legend.FormatString = "<ITEM_LABEL>" & "<DATA_VALUE:##.##>"
You can see that all legends display the last Data Value instead of their corresponding values.
Hello Zia,
Thank you for posting in our forums!
If you are beginner, then I would recommend you to use UltraDatachart instead, since UltraChart is a old control and UltraDatChart is much more feature rich and have better performance.
You can find examples of the UltraDataChart and documents here:
UltraDataChart Samples : www.infragistics.com/.../overviewDocs: https://ko.infragistics.com/help/winforms/datachart-datachart
Now about legend formatString look like you are using the correct property but may be missing “)” bracket is causing the issue , try this: "<DATA_VALUE:##.##>"
Also I did some research and find this post might also help, provide multiple ways to display column values in legend in UltraChart.
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/87132/display-column-values-in-legend
If you need further assistance with this, please let me know.
Sincerely,
Divya Jain
