I am having all sorts of issues moving from one system to a newer system for Infragistics. I have provided screen shots with the issue.
This worked on my older machine.
Hi Colin,
I am glad that you were able to resolve the conflicting references.
Regarding your second query, I suppose it is a similar issue to the one discussed in this recent forum thread, created by you.
Please, keep in mind that according to our policy we handle a single thread per issue, so I suggest continuing this discussion in the above mentioned thread.
Regards,Bozhidara PachilovaAssociate Software Developer
I have one more question that relates to above. Above I went to the single version 18.2. When I click on my tab control from Infragistics I no longer have the ability to go into another tab to edit single controls I placed inside that tab.
Hello Colin,
Thank you for contacting Infragistics Developer Support.
From the second screenshot, I can see that you have referenced assemblies from both version 19.1 and 18.2 in the same project. The controls that you are using exist in the .dlls from both versions, being the reason for the errors.
So, I would recommend upgrading the project to a single version only.
