802
Checkbox in column header
I am utilizing a sample project that I found on KnowledgeBase;
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4883
The issue that I am having is that when the grid is in groupBy mode, when checking the checkbox for any boolean column not all values in that column are checked off like you would expect. I like that only the boolean column in the group that i click in gets updated, however the checkbox for the boolean column in every group gets checked and not its values. Is this a bug in the sample code provided? Can someone help me with this issue. Thanks.
Adrian
