Out of the blue I am getting that error. If I disable the ribbon it goes away, but as soon as I enable it I get the error. Here is the entire stack trace. Any ideas?
Exception Source: System.DrawingException Type: System.ArgumentExceptionException Message: Parameter is not valid.Exception Target Site: AddPath
---- Stack Trace ---- System.Drawing.Drawing2D.GraphicsPath.AddPath(addingPath As GraphicsPath, connect As Boolean) QADB.EXE: N 240285 Infragistics.Win.UltraWinToolbars.QatTopAreaUIElement.GetLeftCurvePath(rect As Rectangle, isBorderPath As Boolean) QADB.EXE: N 01018 Infragistics.Win.UltraWinToolbars.QatTopAreaUIElement.GetCurvedRegion(rect As Rectangle, isApplicationMenuVisible As Boolean) QADB.EXE: N 00097 Infragistics.Win.UltraWinToolbars.QatTopAreaUIElement.get_Region() QADB.EXE: N 00086 Infragistics.Win.UIElement.DrawElement(defaultDrawParams As UIElementDrawParams&) QADB.EXE: N 00708 Infragistics.Win.UIElement.DrawChildElements(drawParams As UIElementDrawParams&) QADB.EXE: N 00046 Infragistics.Win.UIElement.DrawElement(defaultDrawParams As UIElementDrawParams&) QADB.EXE: N 01402 Infragistics.Win.UIElement.DrawChildElements(drawParams As UIElementDrawParams&) QADB.EXE: N 00046 Infragistics.Win.UIElement.DrawElement(defaultDrawParams As UIElementDrawParams&) QADB.EXE: N 01402 Infragistics.Win.UIElement.DrawChildElements(drawParams As UIElementDrawParams&) QADB.EXE: N 00046 Infragistics.Win.UIElement.DrawElement(defaultDrawParams As UIElementDrawParams&) QADB.EXE: N 01402 Infragistics.Win.UIElement.DrawHelper(graphics As Graphics, invalidRectangle As Rectangle, doubleBuffer As Boolean, alphaBlendMode As AlphaBlendMode, clipText As Boolean, forceDrawAsFocused As Boolean, preventAlphaBlendGraphics As Boolean) QADB.EXE: N 00487 Infragistics.Win.ControlUIElementBase.Draw(graphics As Graphics, invalidRectangle As Rectangle, doubleBuffer As Boolean, alphaBlendMode As AlphaBlendMode, elementSize As Size, preventAlphaBlendGraphics As Boolean) QADB.EXE: N 00374 Infragistics.Win.ControlUIElementBase.Draw(graphics As Graphics, invalidRectangle As Rectangle, doubleBuffer As Boolean, alphaBlendMode As AlphaBlendMode) QADB.EXE: N 00077 Infragistics.Win.UltraControlBase.OnPaint(pe As PaintEventArgs) QADB.EXE: N 00132 Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnPaint(pe As PaintEventArgs) QADB.EXE: N 00100 System.Windows.Forms.Control.PaintWithErrorHandling(e As PaintEventArgs, layer As Int16, disposeEventArgs As Boolean) QADB.EXE: N 00153 System.Windows.Forms.Control.OnPrint(e As PaintEventArgs) QADB.EXE: N 00095 System.Windows.Forms.Control.WmPrintClient(m As Message&) QADB.EXE: N 00150 System.Windows.Forms.Control.WndProc(m As Message&) QADB.EXE: N 00992 System.Windows.Forms.ControlNativeWindow.OnMessage(m As Message&) QADB.EXE: N 00015 System.Windows.Forms.ControlNativeWindow.WndProc(m As Message&) QADB.EXE: N 00048 System.Windows.Forms.NativeWindow.Callback(hWnd As IntPtr, msg As Int32, wparam As IntPtr, lparam As IntPtr) QADB.EXE: N 00089
I'm getting this error too: though only when I develop under Windows 7. It's fine on XP.
TargetTracker said: I'm getting this error too: though only when I develop under Windows 7. It's fine on XP.
Yes...that is exactly what has been said already.
This issue has been reported and fixed. I have forwarded your message to the DS Manager. They will add you to the notify list so you will be notified when the fix is released in a hotfix.
Could you add me to that list as well please?
mebstein, I have also notified the DS Manager to add you to the list as well.
Had the same problem here.
Please add me to the notification list, too. Thanks.
I'd like to be added to this notification list too. What's the incident number for the bug?
~Karen
The incident number is 13638. However, it looks like this was already released in a service release. Try to upgrade to the latest service release for the version you are using.
