90
Confused about ultragird displaylayout listobject and listindex
Hello guys sorry if this question was posted many times but i searched and so far no answer satisfactory enough.I a bit new to infragistics.I'm using the version .NETAdvantage 2007 vol 2 CLR 2.0 and this is my first project.
here is my problem.
I've tried using the ultragrid with an objectdatasource or a webservicedatasource collecting an array of an object and it's works very well.so to access an activerow data i use
private void utAllUsers_AfterSelectChange(object sender, AfterSelectChangeEventArgs e)
            try
                selected = (IUser)utAllUsers.DisplayLayout.ActiveRow.ListObject;
            catch (System.Exception ex)
                MessageBox.Show(ex.Message);
Now the problem is that i've created a simple table (Id | Name | Description) with primary key Id (identity)
i bind the grid to a datatable and when i try to access the id of the active row, it Gives me Compleley other ids and i don't get it at all
here are codes
 private void utgrRights_AfterSelectChange(object sender, AfterSelectChangeEventArgs e)
            UltraGridRow rightrow;
            rightrow = utgrRights.Rows[utgrRights.DisplayLayout.ActiveRow.ListIndex];
            rightid = (int)rightrow.Cells[0].Value;
            Name = rightrow.Cells[1].Value.ToString();
How do i get the correct Id no matter how Sorted is the table? Thanks for reading this!!
Parents Reply Children
