236
Using one UltraDataSource for multiple UltraGrids
I am working on a screen which will handle viewing a certain entity. This entity is rather large. Say 45+ fields/properties.
The data of this entity is catagorized and we want to display its data per category. So i have created a tabbed environment in which each tab represents a certain catagory. Each tab contains a UltraGrid which will display its data (im actually showing x entity's at the same time).
Now what i want to do is load all the entity's from database once and then display a different subset of the data in each grid (tab). How can i go about doing this using the UltraDataSource?
Can i apply the same datasource to each ultragrid and specify which column it should or should not show? And would i do this on the ultradatasource level, or do i need to handle this on the grid level?
Any thoughts, suggestions?
