Docking is not happening when i choose any item inside that.
Inside the docking we are loading the control( ultragrid).if i choose any item from the grid and move the mouse away from the docking panel, then auto hide of docking functionality is not working..
Here is the code we aare used for docking.
_mainDockManager -> name of the UltraDockManager_ctrlTEST -> Object of the control
Runtime Code----------------if (_ctrlTEST == null) { /* Floating Dock Area Pane */ _dockAreaPaneTEST = new DockAreaPane(DockedLocation.DockedRight); _dockAreaPaneTEST.ChildPaneStyle = ChildPaneStyle.VerticalSplit; _dockAreaPaneTEST.Text = ""; _dockAreaPaneTEST.ShowChildPanes(); /* Add To The Dock Manager */ _mainDockManager.DockAreas.Add(_dockAreaPaneTEST);
_ctrlTEST = new EmployeeTESTControl(); _ctrlTEST.IsLoading = true; _ctrlTEST.Dock = DockStyle.Fill; _ctrlTEST.OnWorkItemAssignmentClicked += new EmployeeTESTControl.OnWorkItemAssignmentHandler(OnWorkItemViewAssignment); _ctrlTEST.Show();
/* Create Pane Which Holds Control */ _dockableControlPaneTEST = new DockableControlPane(_ctrlTEST); _dockableControlPaneTEST.Text = "TEST"; _dockableControlPaneTEST.Key = "TESTTAB"; _dockableControlPaneTEST.FlyoutSize = new Size(950, -1); _dockableControlPaneTEST.Pinned = false; _dockableControlPaneTEST.Settings.AllowClose = DefaultableBoolean.False; _dockAreaPaneTEST.Panes.Add(_dockableControlPaneTEST); }
Please let me know how to resolve this issue. Its quite urgent.
I'm having a similar problem. I've tried calling Focus, Activate, and BringToFront on the form and Flyout on the dock pane with various combinations of parameters without any luck. Actually the form does appear to have focus, because if the first control on the form is a combo and I start typing, the drop down appears in front of the docked pane even through the form is still behind the docked pane.
This sounds like correct behavior. When a control in a dock pane has focus, the pane will not auto-hide. So when you detect that the user is done editing in the grid, you could call Focus() on the Form or some other control not in the grid to auto hide the pane.
