80
UltraTree - error while set the first node of tree be invisible
my application requires refreshing nodes in ultra tree. I want to remove or hide some nodes with specific attributes. One of the deleted nodes is the first node added to the tree.
If I set that node visible = false I get the following error:
"The ActiveNode can only be set to a node that belongs to this control."
If I try to remove that node, I get error:
"Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index"
Here is my code:
- Create a new UltraTree with name ultraTree1
 void createTree()
            //the following code causes problem
            ultraTree1.BeginUpdate();
            ultraTree1.Nodes.Clear();
            ultraTree1.Focus();
            UltraTreeNode _n1 = ultraTree1.Nodes.Add("node 1");
            UltraTreeNode _n2 = ultraTree1.Nodes.Add("node 2");
            ultraTree1.ActiveNode = null;
            //_n1.Visible = false;
            _n1.Remove();
            //the code causing problem
            ultraTree1.EndUpdate();
and the main class:
 public Form1()
            InitializeComponent();
            createTree();//works ok
            createTree(); //get error
I found out that BeginUpdate() and EndUpdate() cause these errors. It works ok if I comment out BeginUpdate() and EndUpdate(). However, I want to use these methods because my tree has considerable large number of nodes.
Do you have any hot fix for that issue ???
I use Infragistics 9.1
