after applying a style, the ultraexpandiblegroupbox has this icon
can you fix that ?
On a hunch, I opened up AppStylist with the Office2007Blue.isl style and realized that in many of these styles, when you select to disable OS themes when creating a new library, the base UIRole's ThemedElementAlpha is set to transparent. If you go to the Misc canvas and select the UI role for the expansion indicator and set the ThemedElementAlpha to Opaque (this is under the "Other" group in the Properties window), the expansion indicator will show as you want it to.
-Matt
As mentioned at the top of the page when submitting a message as well as in other places, these forums are mainly for peer-to-peer support. If you have an urgent issue that needs to be addressed, you should contact the Developer Support group, especially if it might be a bug. This is to ensure that if there is a fix that needs to be made, you will be notified.
Get Help
UP,
it's very important to me !!!!
please fix it !
