240
Working with an unbound column
Greetings,
     I'm pretty new to the utlragrid control so bear with me.  Using VB .Net I've added a grid to a form that saves a GroupKey and a CompanyID to a table in SQL Server.   This portion I have working pretty well but then I was given a requirement to display the full company name on the grid as well which will not be saved to the database.
     I figured an unbound column would be the best approach to this so I added one to the grid and added code to the AfterCellUpdate procedure to populate the company name column when a company id is updated or entered.   Again this worked pretty well as long as I tabbed off the company id cell (another question I have but will post separately).
     The problem I run into is when I open the form and retrieve records.  The companyID displays as it should but the value for the Company Name column does not.   I tried adding code to the cell change event to see once the companyID cell was populated if it would populate the company name column.  However, this did not work.
    So my question is what is the best technique to ensure the company name column populates based on the value set in the company id column.
Parents Reply Children
