A couple of UltraGridRowEditTemplate qusstions:
1. Can I toggle template usage on and off using a button, similar to what I can do with cardview?2. Can I set a fixed location for a template within the grid using something like:
this.ret.Anchor... this.ret.Location...
Thank you.
Matt:
The toggle worked perfectly.
Having a problem with the e.location syntax. I've tried a few variations of e.location.X and e.Location.Y but getting syntax errors. I'm in the BeforeRowEditTemplate event.
Any suggestions?
1) The easiest way to do this is to toggle between setting the RowEditTemplate property to null or to the instance of your template, i.e.:
UltraGridBand band = this.ultraGrid1.DisplayLayout.Bands[0];if (band.RowEditTemplate == null) band.RowEditTemplate = this.ultraGridRowEditTemplate1;else band.RowEditTemplate = null;
2) There's not really a way to fix the location of the template, per se, but you could certainly handle the BeforeRowEditTemplateDisplayed event and set e.Location to a point of your choosing; just keep in mind that this point is in screen coordinates.
-Matt
