200
MultiBand grid performance
Without getting into too much detail to start off, I have a Grid which binds to a BindingList of composite custom objects. The object, ill call them MyObject and MyAggroObject, both have the same properties exposed. The only difference being that MyAggroObject contains a BindingList of MyObjects where MyObject contains no sublist to bind to.
I use summaries on this grid so I have an UltraCalcManger and I subscribe to the ValueDirtied event. When I bind to a BindingList of MyObjects, after my grid loads, the ValueDirtied handler won't get called at all unless i click on a row/scroll/interfact with the grid in some way.  When I Bind to my BindingList of MyAggoObjects, after the grid has loaded I get bombarded with RowCollectionReferenceResynched row within the inner band of the grid. Note that nothing is happening behind the scenes to change the objects that I am binding to.
Now this normally wouldn't bother me but I believe this event, and subsequent ReCalc calls to the CalcManager are causing my CPU cycles on my app to spike to 50%.  This drops to 0, and the events stops being called, when I add a filter to the grid through the UI to filter out some rows.  I only added the handler to the ValueDirtied event to see why the CalcManager was eating up so many cycles. I also didn't notice any spike when binding to a binding list of MyObjects.
So my question is, when should the RowCollectionReferenceResynched event be fired by the CalcManager? Also, I didn't see any references to performance issues with BindingList's on the forum, but has anyone else experienced this CPU spike when Binding with multiple bands?
