Hi All,
I am having a problem while exporting winGrid Records to PDF.attached the screen shots for refrence.as you can see in my first picture for original records in wingrid appears like below.
After Export to PDF it looks like below :Under each Groups columns are Squeezing ..each other..not coming in order as shown above.
Note : Columns widths are already Set at runtime
And After Export to Excel : i am having the below picture where groups columns are missing in excel
so please address the issue :
1 . Why Coluimns are not coming under their respective groups refrence to 2nd picture ?
2. why the group columns are missing in excel export ?
I can't be sure what version this was fixed in (or if, in fact, it is the same issue that was fixed). But it really doesn't matter - there's only one service release available for download: the latest one.
Hi Mike
Presently we are using NetAdvantage v8.2.In which version this has been fixed..?
Thanks & Regards
Prasant Rout
1) What version of the grid are you using? This looks like a bug that was fixed a while ago. Make sure you have the latest service release: How to get the latest service release - Infragistics Community
If that does not help, I think we will probably need you to provide a small sample project demonstrating the issue so we can check it out.
2) The old-style Groups functionality is not supported by the UltraGridExcelExporter. If you are using the latest version of the grid, we added the ability to use groups in RowLayout mode and these will export to Excel.
