430
wingrid refresh
When refreshing an ultragrid I have been having sporadic (or what I thought were sporadic) problems where the grid would go black or flash before the grid was refreshed.
As I have done some more testing, I have found that the grid only seems to exhibit this behavior if you are refreshing the grid from a point where the numbers of rows in the grid does NOT completely fill the viewport (there is no vertical scroll bar).  That is, if I refresh the data and bind to the grid and the grid already had more rows than were visible in the viewport (there IS a vertical scroll bar), I don’t get this flash/black grid behavior.
I have tried wrapping the grid refresh process with Suspend/Resume Layout and Begin/End Update both on the grid itself, its parent control, and the form all to no avail.
Thanks in advance for any assistance.
