I'm using the AppStylist to generate a consistent look-and-feel for my app. However, I have noticed some differences between the style when shown in the AppStylist and in my app. For example, if I create a new style and base it on the Office_2007 style bundled with the IG2007 pack, selected rows in a Grid have a Blue forecolour. However, if I then save that layout and use it in my application, items in the Grid have a White forecolour.
This is actually causing some problems with ValueLists - if you quickly move from my row to another, the cell on the previously selected row with the ValueList "forgets" to change it's style and the forecolour remains white, on a White background - hence it's invisible! It only shows itself again when you hover the mouse over the cell, I assume because this brings up the hover style of the cell.
Any ideas for both of these questions?
Thanks!
Thanks. I've figured out the cause of my first problem. It's because when you drag a Grid on, by default it puts some settings in code (I assume in the intialisecomponent) that change the look and feel. These settings are overriding the appstylist. I ran the ResetLayout function on the Grid at design time and now it takes the look and feel from the Layouts correctly.
It might be worth putting this as a FAQ or something because all of us here fell foul of this problem - it's not really obvious that the Grid has overriden settings by default just by dragging teh control on.
Isaac
I think there are links on the Developer Support Manager's blog page: Vincent McDonald
Mike
Thanks for your reply. It seems that I don't have the latest hotfix. I've been digging around on the website but can't find it anywhere!
The behavior you are decribing in your second paragraph here is a bug that was fixed a while ago. Do you have the latest Hot Fix?
